High-Speed Digitizers
i want to convert 24 bit hex 2's complement to 24 bit decima?
i ll recieve 24 bit hex 2's complement value how i can decript as a decimal value?
(7,437 Views)
Hi m10001111v,
Are you using any sort of High-Speed Digitizer device from National Instruments?  The model numbers begin with "51" as in "5105" or "5122", etc.
If you are not using an NI digitizer, then I woudl suggest you post to another forum group.
If you are using LabVIEW and trying to convert numbers, I would recommend searching in and/or posting to the LabVIEW forum group.
-Andrew
(7,427 Views)
i'm not using NI product,i'm using some other product
(7,422 Views)
