High-Speed Digitizers
niScope_InitiateAcquisition error for a second 5132 USB scope
I have 2 NI5132 USB digitizers.  Either one alone works fine.  But if I plug both into the USB bus, then the last one connected produces the error message "Error BFFA666A   NI Platform Services: No transfer is in progress because the transfer was aborted by the client....."  with a status code of -50405.  This error occurs when the niScope_InitiateAcquisition function is called for the offending scope.  Up to that point, all the needed niScope_ function calls work, namely:
Init, ConfigureVertical, ConfigureHorizontalTiming, ConfigureTriggerImmediate, ActualRecordLength
(6,000 Views)
Hello PhilLC,
According to this KnowledgeBase, the issue you are experiencing is a common incident that arises when using multiple USB devices, and it is a system dependant issue.  Fortunately, resetting the device should do the trick for reestablishing communication.  Please reference Issue 2 in the KB for the steps to resolve the error.
Kyle A.
Chief Applications Engineer
(5,990 Views)
