High-Speed Digitizers
niScope for linux 2.6
Does niScope application software work for linux 2.6? I currently have it running on Red Hat Enterprise 3, but
that's the 2.4 kernel and this is a rather outdated kernel version.
Message 1 of 9
(8,276 Views)
Hello Stephen,
NI-SCOPE 2.9 for Linux supports only the following Linux distributions:
* Mandrakelinux 10.1 Official
* Mandriva Linux 2006
* SUSE LINUX Professional 9.2 and 9.3
* Red Hat Enterprise Linux WS 3
Sean Close
Product Support Engineer
Message 2 of 9
(8,277 Views)
Hey Sean,
I have seen this list before and I am curious why NI supports only RPM distributions? I totally get that NI can't support all distributions but Debian seems like a logical choice since popular distributions such as Ubuntu, Mepis, Debian, Knoppix and over 100 other distributions (according to distrowatch.com) are Debian based.
just curious?
Cheers,
--Russ
Message Edited by Russ Evans on 05-24-2006 12:45 PM
Message Edited by Russ Evans on 05-24-2006 12:46 PM
Message 3 of 9
(8,268 Views)
Stephen - In Sean's list, note that all of the distributions NI-SCOPE supports except Red Hat Enterprise Linux WS3 are kernel 2.6-based.  Therefore, if you can switch to a supported Mandriva or SUSE distribution, you would get a 2.6 kernel.  (If you do switch to SUSE, would you prefer the new version 10.0?  We're considering adding SUSE LINUX 10.0 support if there is demand.)
Russ - Thanks for the feedback on Debian and variants.  Unfortunately, there are so many Linux distributions, variations, and versions, we've had to be very, very selective about what we support.  Debian did not make the list.
Vince Shouba
NI software developer
Message 4 of 9
(8,236 Views)
If every other distribution you support is 2.6 based, how come you guys haven't upgraded to RH 4?
Message 5 of 9
(8,231 Views)
Hi Vince,
Thanks for the reply. I really applaud NI's efforts into Linux for it's products I just hope decisions like which distributions to support get a periodically reexamined.
In that vain I feel NI almost has to support SUSE 10 if it's going to support SUSE at all. The idea that 6 months from now you would still list SUSE 9.3 as being supported seems questionable since most SUSE users would have switched to 10 and are already eyeing ver 11.
Cheers,
--Russ
Message 6 of 9
(8,223 Views)
RH4 presents some unique technical obstacles.  A reduced kernel stack size makes complex driver software like NI-SCOPE more difficult.  I can't give you a timeframe for RH4 support.  If you need kernel 2.6, I would advise using one of the supported Mandriva or SUSE distributions.
Vince Shouba
Message 7 of 9
(8,211 Views)
No Sh*t... And I thought Red Hat was the leader in Linux distributions. I wonder why the reduced the stack size in RH 4. Will
this change in RH 5? Do you know what the kernel confiuration is for Fedora Core 5? Having to learn another linux distrubtion
will be a pain...
Message 8 of 9
(8,209 Views)
Hi Stephen,
The following seems to indicate you can increase your Fedora stack size.
http://ndiswrapper.sourceforge.net/mediawiki/index.php/Fedora
cheers,
--Russ
Message 9 of 9
(8,203 Views)
