High-Speed Digitizers
niscope error codes
Does anyone know where I can find a list of the error codes produced by niscope VIs and what they mean?
(7,454 Views)
Hi ESD,
Since error codes often change between revisions, there is no document that contains a comprehensive list of all of the error codes.  However, you can find the  current error code numbers listed in the niScope.h file.  You can find the file at:
Program Files \ IVI Foundation \ IVI \ Include
The error codes for niScope currently range from 0xBFFA4001 to 0xBFFA4036, with the exception of "Invalid Session", which has an error code of 0xBFFA1190.  You can use the niScope Error Message.vi to return the error message associated with each code.  This is the best way to make sure you have the error message from your current version of niScope
-John
John Passiak
(7,415 Views)
Ok, Thanks.
(7,380 Views)
