High-Speed Digitizers
where can i find a example for ni pcie 6537
Hi:
where can i find a example for ni pcie 6537?
  thanks!
(7,402 Views)
It depends on your programming language after installing HSDIO driver.
If you're using LabVIEW, you can select Help->Find Examples...Then double click Hardware Input and Output->Modular Instruments->NI HSDIO, you can find some examples to refer on.
If you're using other languages, you can open the folder which locates in:C:\Documents and Settings\All Users\Start Menu\Programs\National Instruments\NI-HSDIO\Examples to find shortcuts of examples path.
Best Regards,
Application Engineer
(7,343 Views)
The NI 6537 is actually programmed using NI-DAQmx, not NI-HSDIO.
(7,337 Views)
Sorry, I have to correct former answer. PCIe-6537 is factually drived by DAQmx. Also you can find examples according to your application software.
If using LabVIEW, you can find these in the following path: C:\Program Files\National Instruments\LabVIEW 8.x\examples\daq
If using Visual Basic or Visual C++, please find examples in: C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples
Best Regards,
NI Application Engineer
(7,305 Views)
