High-Speed Digitizers
pci-5114 two channels->simultaneous acquisition
hi,
i dont manage to find out whether it's possible to acquire samples on both channels at the same time.
if so,how?
when using the visual c exmamples given,
it possible only to sample from on channel at specific time.
thank you very much !!
(6,263 Views)
Instead of just setting your channel name to 0 or 1 try setting the channel name to "0, 1". This lists the channels to read waveforms for and should allow you to acquire from multiple channels at once. I hope this helps!
(6,239 Views)
