High-Speed Digitizers
read data from tds 210 at xy mode?
(7,133 Views)
I am not sure what your specific question is, but I wanted to point out that we do have  instrument drivers for the tds 210 at ni.com/idnet.
That's a good way to get started with programming the instrument. Hope this helps.
Ebele O.
(7,122 Views)
Thanks for answering ,
 I just couldn't figure out from the N.I driver how to read data from two channels simultaneously in order to plot a real time xy chart as seen on the scope screen.
A small (big) tip will be halpfull.
Thanks y.h
(7,105 Views)
Hi y.h.,
I found this link to a knowledgebase that you should find helpful. The forum post here also has a VI that implements the suggestion in the knowledgebase. Hope this helps. Thanks!
Regars,
Ebele O.
(7,087 Views)
 Hi, Ebele O
Thanks for the tips.
(7,073 Views)
