High-Speed Digitizers
when i run the exe file, it need to load the niscope_32.dll why?
Hi:
I have used the  scope functions in my program,
then i made it into exe file and Installer file,
but when i cope them to another computer,
It need to load the niscope_32.dll,what should i do ?
(7,148 Views)
Accepted by ylongwu
Hi ylongwu,
You will need to install the NI-Scope driver onto the deployment computer so that you code can make calls to the driver. You have the option of downloading the driver from our website at the Drivers and Updates link below by searching for our NI-Scope driver and choosing the appropriate version. I would also recommend that you include the NI-Scope driver as an additional installer for your executable. In the build installer window there is a Category called Additional Installers where you can choose drivers and run-time engines to install along with your executable. I have included a screenshot to show what this will look like for LabVIEW 8.x.
Drivers and Updates
http://joule.ni.com/nidu/cds/fn/p/lang/en
Scope installer
Message Edited by Steve_B on 03-02-2009 03:16 PM
Steve B
(7,121 Views)
thanks
the problem have been solved
when i load the ni scope driver
i put the labvied driver CD-ROM in the computer and it load the file automatically
there are all three cd_rom and it informs you to put in a special one
(7,097 Views)
