Hobbyist Toolkit
Anyone having success building a .so file and running in LINX?
Accepted by bbelley
There is no real difference in terms of compiling a shared library. That’s very much independent of the LabVIEW version. You don’t use LabVIEW for that but a properly installed gcc development environment!
Rolf Kalbermatter  My Blog
Message 11 of 12
(775 Views)
C/C++ Development Tools for NI Linux Real-Time Eclipse Edition highest available version is 2017, there is no 2020 version!
I used ARM-based targets, 2017 software stack settings from the article. Then I successfully compile Linx and SQLite from sources and they work under LINX distro included in LabView 2020 Community edition. Tested on Raspberry Pi 2B and 4B.
Message 12 of 12
(773 Views)
