Hobbyist Toolkit
How to download a Vi to a vi to pi zero 2W ?
I'm new to the RPi targets.
How can I get a Vi to run on a pi Zero 2W since it doesn't have an ethernet connection?
Is this possible?
Joel
(1,016 Views)
It is possible, but you will need to setup the wifi on the Pi so it has an internet connection and is on the same LAN as the host PC.
(944 Views)
The RPi is setup with wifi internet connection on the same LAN as the desktop.  I'm able to access the RPi with Putty from my desktop.  It will not connect as a target in the LV project dialog.
I tried using a RPi3B+ and had the same results.
Have you connected without an ethernet connection and used a wifi connection as you mentioned?
(878 Views)
