Hobbyist Toolkit
I2C speed limit on MCP 4725
Hello everybody,
I am using an MCP4725 DAC with LabVIEW LINX and GPIO on a Raspberry Pi 5. In my program, I am running a timed loop with a 300-microsecond period.
Although the MCP4725 supports an update rate of 200 kHz, my loop consistently overruns, meaning each iteration takes longer than 300 microseconds.
I tried increasing the I²C bus baud rate on the Raspberry Pi to 400 kHz, but this did not improve the results.
You can find the diagram in the attached image.
I would appreciate your kind assistance.
Shdkia
Message 1 of 1
(31 Views)
