Hobbyist Toolkit
New experimental LV RPi/BBB installation feature now available
Sorry to hear you are struggling.
First I just want to mention that at least in the past lv on raspberry pi was only permitted to be used for noncommercial usage.
Now to the problem you have. The link you provided to turn it into a master slave is most likely not applicable to raspberry pi. This is a feature of cRIO targets from NI.
What you could try is to use the modbus toolkit and build the necessary server code you need on the host. However it seems someone has tried this with a RS485 HAT in the past and not succeeded. See this https://forums.ni.com/t5/Hobbyist-Toolkit/VISA-resource-name-on-Raspberry-Pi/td-p/4221252
modbus lib on vipm: link https://www.vipm.io/package/ni_lib_modbus_library/
When it comes to your pico code it will not be able to run in LV-environment on  raspberry pi. That is for use with python what it looks like and you would want to use a different os install that supports you modbus server code in python.
Best regards
JM, LabVIEW CLA
Message 21 of 39
(1,670 Views)
Delete double post.
Best regards
JM, LabVIEW CLA
Message 22 of 39
(1,669 Views)
Thank you JonasM,
I am reading this article and hopefully it will help Connect LabVIEW to Any PLC With Modbus - NI
Thanks again!
Message 23 of 39
(1,662 Views)
That way works well on windows and ni rt targets. I'm very unsure if it works on raspberry pi. I think your best bet is the toolkit I linked in previous post. You would have to code the server side on the main vi of the raspberry pi. There are examples how to use that toolkit. I've seen many posts on the forum about. Can't find them now on my phone though..
The method you are reading about and the API I'm talking about is described here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHcFCAW&l=sv-SE
Best regards
JM, LabVIEW CLA
Message 24 of 39
(1,655 Views)
Hello, I am doing a project for the university, I would be very grateful if you could provide me with some links that can help me communicate my raspberry pi4 with labview since I cannot find useful material.
Message 25 of 39
(1,363 Views)
Hello OleSenju,
The github repo does explain the steps you need to take to get your raspberry Pi installed. What step is it that is not working?
Installing an image with LabVIEW pre installed · LVMakerHub/LINX Wiki · GitHub
Also we have a blog post on our website that talks about getting started with Raspberry Pi.
Getting Started with Raspberry Pi in LabVIEW - Novator Solutions
Best regards
JM, LabVIEW CLA
Message 26 of 39
(1,357 Views)
The problem is in the library, the photo shows what I get when you oppress hobbystl >> target configuration
It appears on the front panel and not as an emerging screen
Message 27 of 39
(1,353 Views)
This is the problem, I cannot scise to the configuration screen to connect the raspberry
Message 28 of 39
(1,354 Views)
The photo you have attached is showing a front panel of a VI (program) that is not running.
You have to run it by pressing the run arrow, or ctrl+R shortcut. Then you can click on the buttons.
Best regards
JM, LabVIEW CLA
Message 29 of 39
(1,349 Views)
Your code is broken, probably missing dependencies, click the broken run arrow to get more detailed information.
Best regards
JM, LabVIEW CLA
Message 30 of 39
(1,350 Views)
