Hobbyist Toolkit
Reading PWM from Arduino and my signals are not square waves. How can I fix this guys? (See attached code)
My hardware configuration:
Block diagram:
My Arduino connection:
My signals
Obviously, you can see that these signals are not square waves and my PWM = 50% or 0.5.
How do I fix this?
(1,984 Views)
You're not sampling fast enough, as per the Nyquist theorem, you need to sample at least twice faster as the maximum frequency of interest.
More over, you're sampling one sample for every duty-cycle which is not even a waveform.
Santhosh
Soliton Technologies
(1,967 Views)
So do you think maybe I should have two loops.
one loop that writes PWM at a slower rate (maybe 1000 ms) and another that reads PWM very fast (10 ms).
what do you think? Is that a good approach? What would be your suggestion?
(1,940 Views)
Few inputs,
  1. Do not update the PWM duty cycle for every iteration of the while loop, do it only when you change the duty cycle
  2. Read Digital input at regular intervals and not as fast as possible
  3. You cannot separate them into two loops as both talk to the same Arduino and Arduino can do only one thing at a time.
These should give you better looking representation of the PWM Generated but not the realistic one as Arduino's are not DAQ devices to sample at a high rate and stream with reliable timing accuracy to the PC.
Santhosh
(1,917 Views)
