This widget could not be displayed.
Hobbyist Toolkit
steps to use Raspberry Pi via LabVIEW
So
Can you tell me the steps to use Raspberry Pi via LabVIEW
Which version of LabVIEW Worked for you and what did you install after to get raspberry pi support?
(2,657 Views)
This is a good tutorial for getting up and running with the Raspberry Pi: https://www.youtube.com/watch?reload=9&v=FkDM3-f_CpI&t=3464s
He also did another series which I have previously linked:
https://www.mediamongrels.com/make-ing-with-labview-raspberry-pi-part-1-introduction/
https://www.mediamongrels.com/make-ing-with-labview-raspberry-pi-part-2-installation-configuration/
https://www.mediamongrels.com/make-ing-with-labview-raspberry-pi-part-3-raspberry-pi-setup/
https://www.mediamongrels.com/make-ing-with-labview-raspberry-pi-part-4-user-interfaces-with-labview...
I have had no problem getting LabVIEW 2020 Professional working with Raspberry Pi OS (32-bit) with desktop Version: August 2020 Release date: 2020-08-20.  Here is a post where I detailed what I had installed and what I had to do: https://forums.ni.com/t5/LINX/LabVIEW-2020-Professional-Required-Software-for-Raspberry-Pi/td-p/4099....
Since you created https://forums.ni.com/t5/LINX/Fix-for-All-of-Your-LabVIEW-LINX-and-Raspberry-Pi-Problems/m-p/4117493... what combinations did you try that did not work?  I have not tried LabVIEW 2020 SP1 Professional since it was release a month ago nor have I tried the latest Raspberry Pi OS, January 2021 Release date: 2021-01-11.
David Wilt
The New Standard LLC
(2,569 Views)
