IF-RIO
ADC Microport address write error
Hi everyone,
I am trying to learn how to use the IF RIO PCI 5640 for a project in my class. I have been able to run the first tutorial (single tone output) and it works just fin. Problems arose when I ran the second project, based on the available 'analog input and output' template. At first the FPGA interface pallete was missing from the functions menu. A reinstallation of the drivers and the FPGA module solved this.
I followed all the instructions given in this tutorial: http://digital.ni.com/manuals.nsf/websearch/1F9D087D7EA6E58F862572C80078C0A2, but now I get this error when I try to run the host vi: "ADC Microport address write error". I am not sure what I am doing wrong. Any help/suggestions would be greatly appreciated.
Thank you,
Vasile
(5,751 Views)
Hello Vasile,
As you may have noticed already, that version of the getting started manual has been removed from the web and replaced with this one. There were obviously issue with the previous version, which you found out. Hopefully this new version provides no problems but please post back if you find anything wrong and we can investigate and make any necessary revisions/workarounds if needed. Thanks for posting on the IF-RIO forums!
Chris W
(5,689 Views)
