IF-RIO
About using FIFO Clear in FPGA Module 5640R
Hi all,
I am using three target-scoped FIFOs to stream data in my FPGA module, and they are in three paralell while loops(not SCTL).After using them, I wanna clear the FIFO content. According to the help info of FIFO clear function, I put three FIFO clear functions in one flat sequece. But, I am always getting the compilation error saying error code 6, and it is king of saying some synchronization clock signal is used twice(and thus causes the error). I tried to put only one FIFO clear fuction in the flat sequence, it is OK. But I have to clear all my FIFOs, so How to deal with this trouble?
ERROR:HDLParsers:1202 - "C:/NIFPGA85/srvrTmp/LOCALH~1/SU2190~1/rvi_sunny_FPGA_vi_FPGACompileCopy1.vhd" Line 3839. Redeclaration of symbol OClk.
ERROR:HDLParsers:843 - "C:/NIFPGA85/srvrTmp/LOCALH~1/SU2190~1/rvi_sunny_FPGA_vi_FPGACompileCopy1.vhd" Line 19940. Formal OClk of NI_LV_Queue_ACK_F3ED8139500D489 is used twice.
Total memory usage is 460640 kilobytes
Number of errors   :    2 (   0 filtered)
Number of warnings :    1 (   0 filtered)
Number of infos    :    0 (   0 filtered)
ERROR:Xflow - Program xst returned error code 6. Aborting flow execution...
I attach the screen shot here.
Thanks!
Sunny
(6,278 Views)
Hi Sunny,
Thanks for the question and sorry that no one has gotten back to you sooner. Try putting the Clears each in a different sequence of the continuous sequence structure. You currently have them all in the same sequence. Just right click the sequence structure and say add frame after . Do this twice. Then place your other two clears in each one of those sequences. That way there will be one clear per frame.
RIO Embedded Hardware PSE
CompactRIO Developers Guide
(6,242 Views)
