IF-RIO
Reflection about the arithmatic performance of the VIRTEX-IIP30 FPGA on 5640R
Hi all,
Although I realized several signal acquisition and processing tasks using the 5640R board, I am still not sure about the actual arithmatic performance of the FPGA onboard.
My question is how fast on earth(maximum)can the 5640R process the recieved baseband data samples?
For example, I configured the AI clock as 25MHz, so the data points come in at  every 0.04us. If I perform certain DSP algorithm on the data, how fast can the FPGA handle(e.g. how many addition and multiplication operations per second can the FPGA achieve?)
Referring to Xilinx, I know there are  2 PowerPCs in the FPGA, but how does LabVIEW FPGA take use of them?
The reason I ask all of these questions is because I am trying to implement some real-time signal processing on the sampled data inside the FPGA, but not sure about its operation performance. Based on my past knowledge of 5640R, I know the AI clock before division is 200MHz, so the fastest clock speed I can use is 200MHz, but how many arithmatic operations can be done in one clock cycle?
Thanks very much!
Sunny
Message 1 of 1
(6,254 Views)
