IF-RIO
An internal software error has occurred. Error code: 1003
Dear, I am working on a FPGA programming. When I use the VI: "High Throughput Add Function". Some error occur.
Internal software error(s):
    Error code: 1003 (refer to details)
Details:
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 1003 occurred at E:\Program Files (x86)\National Instruments\LabVIEW 2012\vi.lib\rvi\FXPMathLib\FxpAdd\modGen\nifxpmath_Add_EmitCode.vi: There's a broken VI
(9,211 Views)
Hello Yjin,
Can you show me a VI in which this error occurs?
Which software versions are you using?
An easy way to find this information is as follows:
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(9,200 Views)
