IF-RIO
Max loses connection with cRio in work time
Hello All
I have a new problem with cRio 9074
Max loses connection with cRio in work time. But network connection is ok. I can see it from cmd window.
After restarting cRio, connection recovers.
It becomes more and more frequently.
(9,837 Views)
Hi Manushak,
Please let us know approximately when you loose connection. It is at random intervals or can you spot a trend?
When you loose connection with the cRIO in MAX can you connect to it using the LabVIEW project explorer window?
Regards
Arham H
(9,828 Views)
Hello Arham
My cRio loses the connection in MAX and in Labview project randomly, but i can see connection in CMD with ping.
I have 2 moduls NI 9423, NI 9501 in my project
(9,822 Views)
Are you monitoring the memory and CPU usage from the distributed systems manager? And are you running the application in interactive mode? If the CPU is heavily loaded the code may still be running but the communication with the host PC is probably being interrupted.
I am interested to see what results you get from monitoring the memory and CPU usage in the distributed systems manager.
Regards
Arham H
(9,812 Views)
I had monitoring the CPU usage and saw the worst results, and may be it is the reason of losing the conection.
Thank you for good advice.
(9,803 Views)
