IF-RIO
Create FPGA project without NI board
Is it possible to create an FPGA project without having R series board connected?
Can this project be run in emulation mode?
Thank you,
(10,218 Views)
Hi Mejdi,
Here is a knowledgeBase article on simulating FPGA Hardware Targests in LabVIEW:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YI6yCAG&l=en-US
Peter T
(10,206 Views)
When I select Add Target and devices, the list of new Target or device is empty!
Any Help?
(10,197 Views)
HI Mejdi,
Do have the NI-RIO driver installed?  You don't see any of the simulated devices until you install this.  Here is the compatibility sheet for NI-RIO installations for LabVIEW:
https://www.ni.com/en/support/documentation/compatibility/17/ni-rio-and-labview-version-compatibilit...
Once you determine which version you need, you can find it for download on our website.
Peter T
(10,176 Views)
