IF-RIO
DAC_IQ_Clk to less than 1MHz??
I am using PCI5640R.  Can i send the IQ samples at a rate less than 1MSps frm host to target. coz when i set the DAC_IQ_Clk to a rate less than 1MHz,I am getting the error which says that nominal freq is 1MHz to 100MHz.
(5,771 Views)
you have make the PD clock of the DAC to the frequency of the data rate, not DAC_IQ _CLk which push the IQ data after interpolation.
Gothrough the AD9857 manual. You will get this.
Message Edited by Vinny ICS on 06-01-2009 02:59 AM
(5,720 Views)
