IF-RIO
Driver VI to configure the DAC of NI5640R in the interpolation mode
I need the Driver program to configure the DAC of NI5640R in the interpolation mode.
Or
How to configure the DAC of the NI5640R in the in the interpolation mode.
(5,858 Views)
In Interpolation mode, only I data is considered and mixer is bypassed. Using the quadrature mode, you can try doing the same. Set data only on I (Q=0) and carrier frequency=0. Make sure the signal frequency components are >250kHz as the output is AC-coupled. Hope this works for your case.
--Vinay
(5,845 Views)
