IF-RIO
FIR filter core within SCTL
I have generated a xilinx FIR filter core to be able to give one ouput sample per clock cycle.
I am trying to filter incoming I and Q samples in SCTL linked to ADC_0_Port_A_Clk.
Within SCTL, I am using HDL node interface routine to import filter core.
So far I have not seen any success.
There are few issues I still cannot figure out about SCTL.
1. Which clock would the FIR would be using within SCTL? ADC_0_Port_A_Clk or Configuration_Clk?
2. Is there anyway to access ADC_0_Port_A_Clk within SCTL?
3. In this SCTL, what is the relationship between enable_in and ADC_0_Port_A_Clk signals?
Thank you,
PHPATEL.
(6,986 Views)
It should work on the ADC_0_Port_A_Clk.
When you're on an SCTL your enable_in signal is enabled as long as the loop is active.
- Mauricio
(6,975 Views)
Que onda Mauricio, Hasta que di contigo, soy Edgar del Pierre Faure, espero leas el mensaje, estoy organizando una comida de la generacion de secundaria, yo se que vives fuera y seria complicado que vinieras es el 20 de mayo, de todas maneras pasame todos tus datos a mi correo edgar@ivector.com.mx  para incluirte en el directorio.
Saludos.  tambien agrega tu msn para comunicarnos
(6,943 Views)
Hi
I think you posted this to the wrong NI Message board.  This is meant for help with the NI PCI-5640R IF Tranceiver.
If you wish help in another area, I would suggest posting to the Spanish language board:
Discusiones sobre Productos NI
http://forums.ni.com/ni/board?board.id=6170
Have a great day.
Jerry
PS: Mauricio says Hi.
(6,937 Views)
