IF-RIO
Invoke Method for ADC fails to appear in the host VI
   I write up the vi for the FPGA to acquire IQ data from ADC. Now the FPGA vi pass the compilation and I proceed to programme the Host vi. However, as I write right click the Invoke Method, there is no option for ADC 0. I recompile and the problem persists.
   I attached my vi here.  I would really appreciate any hints or suggestions.
   Thanks.
David
(6,298 Views)
Hi David,
I'm not sure what you mean by "there is no option for ADC 0". The method node is supposed to show the follwing options: 1) Run, 2) Abort, 3) Reset, 4) Download, and, if you have any DMA FIFOs in your FPGA VI, then it will also let you read from or write to the DMA FIFO. I've opened your project and I get all the options, including one for reading from the FIFO named "Data to Host".
Could you please elaborate on what are you trying to do?
- Mauricio
(6,292 Views)
