IF-RIO
NI PCI-5640R Documents
Here is some info on the NI PCI-5640R.  All the following information is installed with the NI PCI-5640R installer.
The NI PCI-5640R's Help file, Getting Started Guide and Specifications are the attatched documents.
In addition, more specific details on the module's operation and capabilities can be found in the module’s component data sheets.  The following are the major components of the module:
AD6654 - 14-Bit, 92.16 MSPS, 4 & 6-Channel Wideband IF to Base Band Receiver
Analog Device Information page:
AD9857 - CMOS 200 MSPS 14-Bit Quadrature Digital Upconverter
http://www.analog.com/en/prod/0%2C2877%2CAD9857%2C00.html
DataSheet
http://www.analog.com/UploadedFiles/Data_Sheets/28341907AD9857_c.pdf
3.3-V High Performance Clock Synthesizer & Jitter Cleaner
Texas Instruments Information page:
http://focus.ti.com/docs/prod/folders/print/cdc7005.html
DataSheet:
http://focus.ti.com/lit/ds/symlink/cdc7005.pdf
(6,477 Views)
Thank you very much for the links and the files.
(6,473 Views)
