IF-RIO
HOST to FPGA DMA Transfers
We're having trouble using the Host to FPGA DMA feature available in LabVIEW 8.20 with IFRIO. After starting a compile, we get the following error message:
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error -61048 occurred at This target does not support DMA Output (from the host to the target).
Possible reason(s):
LabVIEW FPGA:  This target does not support DMA Output (from the host to the target).
Any help would be greatly appreciated.
Thanks.
(6,407 Views)
Hi Manik: We did not support DMA output on the PCI-5640R when we released NI-5640R 1.0. This is why you are getting the error message that you are seeing. We plan to add support for DMA output in an upcoming release. ----abhay
(6,387 Views)
