IF-RIO
Quarter bridge for 9237
How do I select quarter bridge completion settings for 9237 with 9944?
Message Edited by Frederico Barros on 09-28-2007 09:02 AM
(6,153 Views)
The 9237 is capable of full and half bridge measurements without addition equipment. In order to take quarter bridge measurements with the 9237 you need a quarterbridge completion resistor component (like the ni 9944). This turns your quarterbridge configuration into half bridge, which the 9237 can do. You will need one of these completion components for each of your strain gauges.
[will work for kudos]
(6,044 Views)
