IF-RIO
Which opkg repository to use?
Have been seaching the forums and Internet.
Please redirect to appropriate forum or direct me to reference if exists.
What is the best opkg repository to point my cRIO-9068 to?  Specifically I am wanting to install Python on the cRIO but will want to examine other core and supplemental packages and compliers available.
The default repositories in /etc/opkg/*.conf point to an angstrom repository that returns 404 not found with a wget when doing: opkg update (see below).
Note: repository site in config file is pingable so network connectivity is confirmed.  However does not respond to telnet port 80 which imples maybe web site down?
Any suggestions or pointers to reference appreciated.
opkg Config Files:
angstrom-base-feed.conf -
src/gz angstrom-base http://feeds.angstrom-distribution.org/feeds/next/ipk/eglib
angstrom-python-feed.conf -
#src/gz angstrom-python http://feeds.angstrom-distribution.org/feeds/next/ipk/eg
Results of an opkg update:
admin@NI-cRIO-9068-01a6fb7b:/etc/opkg# opkg update
Downloading http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/Packages.gz.
wget: server returned error: HTTP/1.1 404 Not Found
Collected errors:
 * opkg_download: Failed to download http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/Packages.gz, wget returned 1.
(17,284 Views)
I think the NI Linux RT forum would probably be the best place for this and it has a lot of useful resources regarding opkg's.
https://decibel.ni.com/content/groups/ni-linux-real-time?view=documents
Aaron L.
Applications Engineer
(17,269 Views)
Accepted by bsmith201
Thanks Aaron,
I can't seem to find that particular forum (still looking).  Any way you can point me to same and I will repost there.
(17,265 Views)
D'oh.  Sorry, just saw the link you posted above.
Heading over there to post.
Thanks for the repay and direction!
(17,262 Views)
