IF-RIO
analog input and output using 5640r
hi everybody, i am aqib , i am trying to implement OFDM on fpga using 5640r. The code i am having, is performing good in simulation using labview and also by using "ni 5640r processing only" but i want to implement it on "analog input and output vi" so that i can transmit and receive it on the same 5640r card after so much attention towards this , i am still unable to find out issue and then the soultion to that issue. one thing that i am able to understand that may be there would be some clock setting issues (DAC and ADC) clocks i have attatched that vi. please have a look at at Regards Aqib College of Aeronautical Engineering Risalpur
(7,859 Views)
Aqib,
I think you forgot to attach the VI.
(7,853 Views)
Accepted by islamabad
sorry
(7,848 Views)
