IF-RIO
cRIO-9114 Chassis "high speed interface slot"
I use a NI-9114 Chassis (8 slots) with a NI-9022 Compact RIO controler.
I need to use 6 devices in "FPGA" mode, is it possible ?
=> One EnDat Device (S.E.A) (Absolute encoder interface)
=> Three NI-9516 Device (Drive interface)
=> One NI-9401 Device (Digital I/O module)
=> One NI-9263 Device (Analog Output module)
I saw that Devices used in "FPGA" mode need "High Speed" interface slot on cRIO Chassis, I'm right ?
If Yes, how many slots can we use to drive devices in "FPGA" mode ?
Thanks for your answer.
Christophe B.
(10,196 Views)
Accepted by Microtec
You could use the entire Cseries module on FPGA mode. Be careful for the module 9516 :
http://digital.ni.com/public.nsf/allkb/C43C73FE11BE740A8625763C006CC3ED?OpenDocument
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(10,185 Views)
Hello Samuel,
Thank's for yous help.
Best Regards,
Christophe B.
(10,180 Views)
