IF-RIO
getting started guide
Please copy and paste and send me the actual image of the LabVIEW Project Explorer Window so i can see what is going on.
J
Message 11 of 22
(4,465 Views)
this the image i can see
Message 12 of 22
(4,467 Views)
Sorry, the image did not make it.....
J
Message 13 of 22
(4,458 Views)
Message 14 of 22
(4,439 Views)
Message 15 of 22
(4,439 Views)
Looking at the Project Explorer Window on the first "page" of this thread, can you use Windows Explorer to browse to the directory ni5640r  Template you copied and renamed, and verify that the VIs are actually in the directory?
You are looking for:
ni5640R Template (HOST).vi
ni5640R Template (FPGA).vi
ni5640R Template.lvlib
J
Message 16 of 22
(4,436 Views)
Actually, can you verify that both the original and copied ni5640r Template directories look like this?
J
Message Edited by Jerry_L on 11-03-2006 07:38 PM
Message 17 of 22
(4,432 Views)
Hi Valli
After thinking this over a bit.  I think you should un-install the ni5640r software as well as the NI-RIO driver.
Check to ensure that the LabVIEW/examples/FPGA/ni5640r directory is removed.
Then go and reinstall the NI-RIO driver (2.1 latest I believe) and then re-install the ni5640r software.
Please check to make sure the example directory has the same files as the image I posted.
Then go back to the Getting Starting Guide.
Jerry
Message 18 of 22
(4,412 Views)
hi,
    Do i have to change the labview version 8.0 to .2 to see the lib file or is there another problem
this is the image that i am seeing when i open the template project
after doing all the steps given in the starter guide(page 11)
Message 19 of 22
(4,399 Views)
hi jerry,
             i have the 1.0 version of ni 5640R that came with the board......
if u ask me to install 2.1 latest can i get it online or do i have to order NI for this CD
Message 20 of 22
(4,393 Views)
