IF-RIO
ni 5640R drivers
Hi Jerry,
thanking you for your reply.
Maximum configured size of the memory in the example is 20k.Even though i generated waveform less then  20k sample i am getting phase changes.
I am not getting wat u told"
Do you believe your issue is due to a part of your waveform being lost?  The previous issue, described as a phase change issue, is actually a waveform size issue, or an incomplete waveform being generated."
what is
waveform being lost and waveform size issue, or an incomplete waveform being generated?
already i told you sir if it is sine wave i am getting properly,if it is modulated wave i am not getting correclty.
frankly saying i am not getting
reason why phase changes are getting.
My frd Sreenivasulu is also working in the same issues.he is using ni 5640r IQ output example project.he is laso getting same problem.
If u want i can send his project files.
We are struggling so much on this issue sir,Please help me.
Thanking you sir
B.Vasu
Message 11 of 11
(2,838 Views)
