Indian LabVIEW Users Group (IndLUG)
Excel to PDF Conversion
Hello Friends,
I am working on one project with a need of converting excel reports to pdf. I explored couple of options on NI forums and found attached can be useful. However it seems, attached solution is developed in LV2018 version. I am using LV2017.
Can any one pl help me convert this project to LV2017 version so that I can refer.
Alternatively, if anyone has a solution to convert to pdf, pl share. I will be really grateful.
Thanks for the support.
-Sandeep
**bleep** Controls.
(5,937 Views)
Accepted by topic author fagcontrols
The method i used requires an add-in for the Office ("Save as PDF"). If you have this you can use ActiveX property to export as PDF.
bp
(5,923 Views)
PFA, your project file saved in LabVIEW 2017 version.
(5,919 Views)
Thank you so much Alifiya and Bharath.
With your inputs I am able to generate the pdf successfully.
Appreciate your much needed help. Thanks a lot.
-Sandeep (**bleep** Controls)
(5,894 Views)
