04-27-2020 02:40 AM
Hello Friends,
I am working on one project with a need of converting excel reports to pdf. I explored couple of options on NI forums and found attached can be useful. However it seems, attached solution is developed in LV2018 version. I am using LV2017.
Can any one pl help me convert this project to LV2017 version so that I can refer.
Alternatively, if anyone has a solution to convert to pdf, pl share. I will be really grateful.
Thanks for the support.
-Sandeep
**bleep** Controls.
Solved! Go to Solution.
04-27-2020 03:18 AM
The method i used requires an add-in for the Office ("Save as PDF"). If you have this you can use ActiveX property to export as PDF.
04-27-2020 03:31 AM
PFA, your project file saved in LabVIEW 2017 version.
04-28-2020 02:29 AM
Thank you so much Alifiya and Bharath.
With your inputs I am able to generate the pdf successfully.
Appreciate your much needed help. Thanks a lot.
-Sandeep (**bleep** Controls)
