09-25-2014 03:00 AM
Good Morning,
I have the following problem:
I am triing to connect a canpopen ni PCI-5831 (Master) with two slave nodes (node 1 and 2).
Using the application.vi from NI-Industrial Communications for CANopen 1.0.3 I can communicate to slave 1 and 2 separately.
I addapted the code to communicate with the two nodes, but only communicates with one, In the second I have an error (CanOpen RPDO Create.vi:1390002) .
I am sending the file attatched.
Could any one help me please?
09-25-2014 08:53 AM
Taking a brief look at the code, it looks like you have an CANOpen Interface Close before the CANOpen RPDO Create, which causes the reference to the interface to close out, which would then cause the error -2147136878, which indicates that the "The object handle passed in is not valid. Ensure you use a correct object handle returned from the CANopen VIs and make sure the object is not closed." I recommend closing the reference out at the end of the code, after the communication with the second device.
02-18-2015 06:14 AM
Hi!
Sorry for reopen this topic, but could you solve it?
I have the same error, but I have all the close TPDOs, RPDOs and Close Interface at the end of the code. Only one node closes perfectly, the rest ( 3 nodes more) has error -2147136878.
I don't understand why.
Thanks![]()
02-18-2015 08:30 AM
Hi Maria,
I recommend showing an image of the code or posting the code so I can take a look. This error typically involves attempting to use an invalid reference, so I would need to see where the invalid reference is being handled.
Thanks!
02-19-2015 06:00 AM
Hi Maria,
Did you create a Batch SDO for each one of the nodes?
Did you edit the Batch SDO for each one of the nodes?
Did you deploy all the batch sdo files before running the vi?
Best Regards,
Valter
