Industrial Communications
Communication to S7 300 PLC using CP5611 A2 Card
i need to collect the data from the S7 300 PLC. i am havin the PC with Siemens CP 5611 A2 Profibus card. i do not want to use any OPC on this.
is there any driver or library avilable for colecting data .
Regards
Sivakumar
sivakumar.rd@gmail.com
(9,452 Views)
Accepted by sivakumarvasan
You may be able to communicate to this board by using DLL calls (call library function in LabVIEW). Please contact Siemens for such an option.
If you are looking for a Profibus device with a native LabVIEW API, you could use this board instead.
Kind regards,
Jochen Klier
(9,450 Views)
