Industrial Communications
DeviceNet support on the 9651
Greetings,
I'm trying to determine if DeviceNet is supported on the 9651. Any information would be appreciated.
Thanks.
(3,874 Views)
You can use NI-IndCom EmbeddedCAN driver instead of NI-IndCom DeviceNert driver, and achieve DeviceNet protocol based on raw CAN frames by NI-IndCom EmbeddedCAN driver.
Thanks!
(3,855 Views)
I find it odd that the NI-IndCom for DeviceNet does not seem to support the sbRIO-9651 yet it has support for the sbRIO-9607 that uses the same Zynq core. Any idea if there are plans to support the sbRIO-9651?
(3,834 Views)
The IndComm for DeviceNet driver supports the NI 9882 DeviceNet C Series module.  The sbRIO-9607 has an RMC accessory (sbRIO-9697) that can support connecting up to 2 C Series modules to the SBC via the RIO Mezzanine Card connector.  The sbRIO-9607 has additional onboard circuitry and capabilities that enable it to support C Series modules, but the sbRIO-9651 SOM does not.  Because the sbRIO-9651 SOM doesn't support the DeviceNet C Series module, the IndComm for DeviceNet driver doesn't support the SOM.
There are no plans to add C Series support (and thus NI 9882 & IndComm for DeviceNet) to the sbRIO-9651.
The poster above was suggesting that if you wanted to repurpose the onboard CAN controller on the sbRIO-9651, you could build a low-level, frame-based implementation of some set of the DeviceNet protocol on the sbRIO-9651 SOM.
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(3,827 Views)
Good info.... thanks. Didn't realize that it wasn't supported through the onboard CAN but instead required the C-Series module.
(3,823 Views)
