Industrial Communications
Using Bus Monitor with NI-9866 & NI LIN Examples to confirm setup
I am having trouble sending messages from my NI-9866 LIN Module and need help confirming my setup is correct.
Hardware:
  • NI-9174 with NI-9866 Module & CAN Breakout Box
Software:
  • LV2016, XNET 16
Steps I have taken:
  • Powered all equipment, all indications show devices are properly configured & wired
  • Opened and tried each of the NI LIN examples in an effort to capture anything sent using the builtin bus monitor
  • I see activity lights flashing during commands on both the mainframe and module.
  • When I try to capture any of the Frames\Signals using the Bus Monitor I get nothing.
  • So, I then tried dragging the XNET Signal Session I created into a blank VI.  It runs, lights blink, no error
    • If I turn on the Bus Monitor and run the VI I get the error shown in the attached pic
Shouldn't I be able to capture the frames\signals I send to the 9866 even if the device on the other end does not recognize the message?  So before I can confirm if I am creating the frames correctly I want to make sure what I send is being broadcast on my small LIN network.
Any help is greatly appreciated!
Message 1 of 1
(3,630 Views)
