Industrial Communications
Using CAN Breakout Box with NI-9866 (LIN)
I am having problems sending LIN Frames to my device and need to confirm I am using the Breakout Box (which says its compatible with LIN).  I am using the supplied 9pin to 9pin cable from the NI-9866 to the breakout box.  Please see the attached pic - Supplied 12V and LIN signal wire as shown (ECU is also grounded at Power Supply).
Message 1 of 1
(3,437 Views)
