Industrial Communications
Drawback of putting producer and consumer in one loop. [Ethernet IP]
Ah Ok, cool. Thanks
Message 11 of 12
(2,616 Views)
@sticyfinger wrote:
I wanted to cut back on the number of loops running in my code. Still I already have two independent loops I didn’t want to add two more loops.
Oops!  My RT code has more than a half-dozen parallel loops (including a Timed Loop in charge of data acquisition), while the Host routine is running at least 10 loops.  In fact, the Real Time Project Templates distributed with LabVIEW 2012 have at least a half-dozen parallel loops for the Host and Remote routines, so having more than two loops isn't so bad ...
BS
Message 12 of 12
(2,604 Views)
