Industrial Communications
Ethernet/IP implicit messaging is possible in labview PC
Hi fra_sab,
If it can get the response with the correct size. I think it has succeeded to communicate with the device. It's possible that the area is all zero. You should contact the device's company for more detailed information.
Did you do a test with other vi? Is there any problem?
Thanks!
Message 11 of 12
(2,003 Views)
the labview ethernet/ip blocks only handle implicit messaging, through those if you can access, some interfaces or brands like smc, if you can open communication with those blocks, but balluff if a little more complicated, I used that same device. in the end I could open communication establish implicit messaging with the same amount of byte.
best regards
Message 12 of 12
(1,281 Views)
