Industrial Communications
I need to measure the movement of flat steel and make correction xy after clamp
We are correcting for clamp movement on a robot arm.  I was looking at vision system with a servo xy correcion.  The robot shifts about .005 in randomly on a clamp before drilling and I need to find an xy plate and vision to look at a steel or titanium surface and mark the change.
(7,617 Views)
alesper,
Thank you for you post - firstly, there are numerous vision component options as far as cameras, frame grabbers, lenses, etc. National Instruments offers these components, mainly the frame grabbers but we do sales a few different types of cameras, lenses, lighting...
As far as the motion part of your system, we also provide components needed to control, drive and interface with your motors.
I can give you more of a detailed hardware/software recommendation if you like - but I need more detailed information on what you are interested in doing.
If you are interested in a turnkey solution I suggest you contact one of our NI Partners https://www.ni.com/en/partners.html:
"Whether you are looking for assistance in completing a small integration project, require in-depth expertise in building a large multifaceted system or solution, or want to find a turnkey solution, National Instruments Alliance Partners have the resources and know-how to provide what you need in every region and every industry."
--Michelle
(7,603 Views)
