Industrial Communications
covert analog input signal (NI 9203) to meaningful units
I'm very new to LabVIEW and I wanted to do something that I thought was fairly simple. Using the NI 9203 analog input module I wanted to measure pressure using a sensor that has an output of 4-20 mA. Altough I get some signal at the end on my screen, it's not realy the pressure. How can I convert this to a meaningful signal? I also took a look at the exeple VI's in the module specific file, but I don't have a clue how to use them.
Hopefully someone can help me out.
Jurgen
(10,409 Views)
Hi Jurgen,
I saw you open two time the same thread one the forum and this one is at the wrong place. So I will reply on the other location.
regards,
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(10,391 Views)
I am experiencing the same problem, can you please direct me to the solution.
Regards
(9,439 Views)
Greetings Mark,
The other thread Julien is talking about is here
Kind Regards,
Wouter - Applications Engineering
(9,424 Views)
