Industrial Communications
Lookout 5.1 - errors with recoursive text expression : test process
For all the lookout developers
I've developed an example with one recoursive text expression that doesn't work correctly.
The lookout verion is the 5.1.
Normally I use this expressions when I develop HMI applications and the example represent the 1% of this expressions.
Thank to all, and enjoy youselves.
Bye
Mario Fanelli
(8,327 Views)
The value on "Recursive text expression" will never be different of a saved and not modified value, unless you make a modification in your process file and save the modifications.
Best Regards
Andre Oliveira
(8,327 Views)
