Industrial Communications
errors with recoursive text expression
Lookout 4.5.x and 5.0 have problems with recoursive text expressions when the process images was saved. When the application restarts,
specially after a system shutdown, the recoursive expression is not loaded with the value that have before the process shutdown.
But sometimes it's loaded with another value prevoiusly processed.
Example of expression:
exp_txt=if(condition,T.member_txt,exp_txt) where:
condition, is a boolean condition of the process supervisored that allow to change the value of the expression,
T.member_txt, is a text member of a data table that value changes due to the status of the process supervisored.
Mario Fanelli
EL.P.R.IND: srl
Gussago (BS) - ITALY
tel: +39 030 322150
fax: +39 030
322240
e-mail: tecdep@elprind.com
admdep@elprind.com
(8,620 Views)
Mario,
Let me see if I can reproduce that behavior. Have you tested it with the new Lookout 5.1 version?
I'll let you know what I find in my own testing.
(8,620 Views)
Thanks cfarmer,
I don't have tested with lookout 5.1, but I test it with the new version as soon as possible.
In a few days, I develop an example with the errors and I send it at the forum.
Bye, Mario.
(8,620 Views)
