Industrial Communications
saving lookout image process file
Does exsists an option to merge at the command lookout.exe -shutdown for force saving the image process file at the process shutdown?
Mario Fanelli
EL.P.R.IND: srl
Gussago (BS) - ITALY
tel: +39 030 322150
fax: +39 030 322240
e-mail: tecdep@elprind.com
admdep@elprind.com
(8,603 Views)
Hi Mario,
No, there is no such an option, whenever using the shutdown command with the Run object for example, make sure you have saved any process file modification, Lookout will shutdown the process and any unsaved modification will be lost.
I hope it helps
Best Regards
Andre Oliveira
(8,603 Views)
Thanks Andre, we can only hope that Lookout developers make something to do this.
(8,603 Views)
