Industrial Communications
Migrating NI-CAN application to NI-XNET delphi
I want to migrate a NI-CAN application to NI-XNET. My application run on a NI-PCI-CAN series 2 and i need it work on a NI PXI-8512 .
I develop with delphi.
I followed the "Migrating NI-CAN Applications to NI-XNET" tutorial : http://www.ni.com/white-paper/9717/en/
I can see the card in MAX like explain in the tutorial.
I realised a small application who show the receive data. That application work well with my first card but didn't work with the new.
From the NI-CAN library i use : ncConfig, ncWaitForState, ncOpenObject et ncRead.
I want my NI-CAN application work on my new card without touch the source code. Is it possible?
(6,380 Views)
Accepted by G.LEGO
That tutorial is only for LabVIEW. I think you will have to modify your source to use the new card.
Jesse Dennis
Engineer
INTP
(6,357 Views)
So i will have to modify my source code.
Thank's for your answer.
(6,327 Views)
