Industrial Communications
Probleme with ModBus and AKD kollemorgen Driver
I'm Beginner in LabView and I have a trouble to read data from my driver AKD Kollemorgen using LabView, I found this VI in this Forum "
It's work if i want to read the feedback position but it didn't work for Current feedback , in fact, in the VI we can see 3 scales factors, the 1000 and 20 OK, but the last factor I make it when comparing to the value figured in the workbench, It's Ok for position but the current change so fast then i can never have a constant factor. Smiley Sad
why i must introduce 3  scales factors ? why registers have not the right value ?
Can someone help me please to read data from my driver without using all this scales factors and using Modbus ???
Thanks !!
(4,583 Views)
Hey chouroukatt,
I'm afraid I don't see the scale factors that you're talking about. Can you attach a screenshot of the VI running?
Also, would you mind providing a little bit more information about how you're connecting to your AKD device?
Ty Prather
Technical Marketing Specialist
(4,528 Views)
