Industrial Communications
Profibus Module not recognized on cRIO-9055
I am having trouble setting up a PB module on a cRIO 9055  I can see the module in MAX but I cannnot add it to a LabVIEW project without an error stating the module is not supported.  I also cannot connect to the PB module through the Kunbus Configurator tool (Driver selection window is always empty). I have verified the PB module is a Master/Slave and verified the VISA settings are correct (I even added the specific IP addresses of the cRIO and the host computer just to be sure).  Any suggestions for what to try next.
Relevant details on build out
Host PC -
Windows 7 64-bit
LabVIEW 2020 32-bit with FPGA and RT modules
Compact RIO 20.0
NI-VISA 20.0 with Visa Server
cRIO 9055
CompactRIO 20.0
NI-VISA 20.0
NI-VISA Remote Passport
NI-VISA Server 20.0.0
NI-RIO 20.0
NI-RIO Server 20.0
LabVIEW RT 20.0.0
Kunbus Configurator III Version 3.1.3.1
Kunbus cRIO PB Master/Slave Version 4.0.1.2
Thank you in advance.
AJL
Message 1 of 1
(1,314 Views)
