Industrial Communications
Programmatically create tags when NI OPC server is offline?
Can I add tags dynamically to an NI OPC server using labVIEW when the server is offline or even better when it is online and running?
(6,119 Views)
Accepted by grootverzet
Have you already tried the steps in the following document?
http://zone.ni.com/reference/en-XX/help/371618G-01/lvdschelp/create_opc_clnt/
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(6,114 Views)
